Back to List
Seafar Scales Semi-Autonomous Fleet Operations with Peplink
Seafar built a teleoperation model that lets shore-based captains control multiple vessels remotely, helping the company scale its fleet despite a maritime workforce shortage. To support this and keep connections unbreakable, Peplink provides the network infrastructure.
Summary
Organization
Seafar, a semi-autonomous and remote vessel operator
Application
Shore-based teleoperation of crew-reduced vessels
Solution Provider
Frontier EU (Peplink Distributor)
Peplink Deployment
BR1 Pro 5G, HD1 Dome Pro, Switch Series, InControl, and SpeedFusion
Project Scope
50+ vessels and 4 remote operations centers
Outcome
24/7 teleoperational uptime, with fleet expected to double within the year
The Challenge
Operating Where Connectivity Is Least Reliable
The Solution
Multi-5G Bonding for Continuous Fleet-Wide Control
The Result
24/7 Control and a Fleet Ready to Double
Testimonials
What I’m particularly proud of is our ability to now scale our operations. From when we were first founded 6 years ago with a single vessel to now operating a fleet of over 50, the Peplink solution and the Frontier collaboration have enabled us to go from one to multiple vessels. We hope this journey continues in the years ahead.
Zia Nassir
We basically shift the job of the onboard captain to a shore-based position, and the Peplink components ensure we can keep an eye on the connection, keep it stable, and avoid very serious damage to the waterway, the environment, or people.
Manolito Fernandez
The transition is very smooth and the system of Seafar is working very well. I think the biggest benefit would be that the crews onboard the ship right now can also work onshore, so they have more time with their families.
Twan Brummelkamp
Deployment Architecture
Featured Products
BR1 Pro 5G
Provides primary 5G connectivity for each vessel and shore center
Integrates fixed-line or other WAN connections alongside dual-SIM 5G, with built-in SpeedFusion support
Compact yet robust form factor built for both fixed installations and constant motion at sea
HD1 Dome Pro
Adds redundant 5G connectivity for network resilience on vessels
Embedded cellular antennas for minimized signal loss and maximized coverage
IP67-rated, weatherproof enclosure to withstand exposure to maritime elements
Switch Series
Offering a range of port densities to match vessel size or shore center demands
PoE-capable to provide power and connect to HD1 Dome Pros and peripherals
Featuring rugged variants built for harsh operating environments
InControl - Cloud Management
Provides oversight of devices across every vessel and remote operations centers from a single dashboard
Eliminates the need for on-site engineers by providing complete visibility and configuration control
Streamlines onboarding, letting new vessels join the existing managed network as the fleet grows
SpeedFusion Technology
Bandwidth Bonding aggregates up to four 5G connections to keep latency low as coverage shifts along the route
Hot Failover maintains teleoperational feed by instantly switching between connections if an individual link fails
Established as SpeedFusion tunnels between vessel and shore to deliver the bandwidth and redundancy for continuous teleoperation
FAQs
Q1. How does Peplink support semi-autonomous vessel operations?
A.
Q2. Is cellular my only option when using Peplink infrastructure?
A.
Q3. How can the Peplink network be managed across a fleet of vessels?
A.
Q4. What Peplink products are recommended for maritime operations?
A.
Next Steps
Talk to a Specialist
Share Your Story
