Introduction
Balance Series
Balance Series (Edge Computing)
SDX Series
Peplink enterprise router lineup including Balance and SDX series models.
Peplink Enterprise Routers
Peplink Enterprise Routers are designed for organizations managing complex, high-availability networks, including enterprise headquarters, regional hubs, and large multi-site deployments, including data center and core network environments where high throughput and redundancy are critical.
What is a Peplink Enterprise Router?
Multi-WAN routers built for organizations that need continuous, reliable connectivity
Speedometer icon representing high performance.
Unbreakable Connectivity
Peplink Enterprise Routers manage multiple internet connections simultaneously such as fiber, cable, 5G, and satellite, and keep traffic flowing automatically when any single link degrades or fails.
SpeedFusion icon representing network bonding.
SpeedFusion
Every model combines routing, VPN, and SpeedFusion in a single appliance. SpeedFusion technology bonds active WAN links at the packet level, so live sessions and active applications continue without interruption.
Learn More
Cloud icon representing network connectivity.
InControl
All models are centrally managed through InControl, Peplink's cloud platform for zero-touch provisioning, remote configuration, and monitoring across any number of sites.
Learn More
Balance Series
Multi-WAN routers for reliable enterprise connectivity.
Multi-WAN routing and local application hosting in one device.
SDX Series
Modular FlexModule architecture. Customize WAN interfaces as your deployment requires.
Ready to Build Your Enterprise Network?
Keep your sites connected and your operations running. Our certified Peplink partners can match you with the right hardware and support you from evaluation through to deployment.
