Peplink Enterprise Mobility Routers
Peplink Enterprise Mobility routers deliver fast, reliable cellular connectivity wherever your operations take you, whether it’s on the road, at sea, or in the field. Built to connect across multiple networks and carriers simultaneously, giving your operations consistent, high-speed connectivity across any carrier in your country.
What is a Peplink Enterprise Mobility Router?
Multi-cellular routers for deployments where fixed lines are unavailable or insufficient
Multi-Network Cellular Connectivity
Peplink Enterprise Mobility routers manage 2 or more cellular connections simultaneously across 5G networks, so vehicles, vessels, and field deployments aren't reliant on any single carrier or cell tower.
SpeedFusion
Every model includes routing, VPN, firewall, and SpeedFusion in a single unit. When a link degrades or fails, traffic continues over the remaining connections without dropping active sessions.
Learn MoreInControl
All models are centrally managed through InControl, Peplink's cloud platform for zero-touch deployment, remote configuration, and monitoring, so IT teams can oversee distributed fleets without being on-site.
Learn MoreDome Series
Outdoor cellular routers with embedded antennas. Designed for vehicle, maritime, and outdoor fixed deployments.
HD1 Dome Pro
A single 5G outdoor router for wall or pole mounting. Supports up to 10 physical SIMs so you can switch carriers without touching the hardware.
Dome Pro Duo
A dual 5G outdoor router for deployments that need 2 independent cellular links. IP67-rated for harsh environments on vehicles and vessels.
Dome Pro LR
A dual 5G outdoor router built for maritime connectivity. High-gain internal antennas maintain a cellular connection at reported ranges of over 25 miles from the coastline.
MBX Series
High-throughput multi-cellular routers for vehicles, temporary sites, and mission-critical mobile deployments.
MBX
Available with 2 or 4 cellular modems for deployments where a single link isn't enough. Supports ignition sensing for vehicle installations and connects across up to 16 SIM cards.
MBX Mini
A compact 5G router that expands to 4 cellular connections via MAX Adapters. Runs on AC, DC, or USB-C power and delivers PoE to connected devices.
PDX Series
Self-contained, battery-powered router for rapid deployment in remote or field environments.
Ready to Deploy in the Field?
Keep your mobile operations connected wherever they go. Our certified Peplink partners can help you match the right hardware to your deployment and support you from evaluation through to installation.
