Back to List
BlueFit Scales Reliable AI-Assisted Pool Safety with Peplink
AI can detect a swimmer in distress within seconds, but only if every camera, every alert, and every connection stays online. With Peplink providing resilient connectivity across BlueFit's facilities, the AI-assisted pool safety system keeps operating reliably at scale.
Summary
Organization
BlueFit (Aquatic facility operator)
Application
Lynxight AI-Powered Swimmer Distress Alerting and Facility Analytics
Solution Provider
Rising Connection (Peplink Reseller)
Peplink Deployment
Balance 310 5G, B One 5G, BR Series, Transit Series, Switch Series, Access Point Series, InControl, and SpeedFusion
Project Scope
30+ Lynxight-protected sites
Outcome
Continuous network resilience via a repeatable, centrally managed architecture
The Challenge
Scaling AI-Powered Pool Safety Across Diverse Facilities
The Solution
One Standardized Connectivity Architecture Across Every Site
The Result
Continuous Availability for Real-Time Safety Across More Than 30 Facilities
Testimonials
Reliable connectivity is essential to our AI-assisted pool-safety operations. Peplink gives us a consistent, resilient foundation that helps keep cameras, alerts and staff devices connected across our facilities.
Roland Karoliny
Lynxight relies on stable network connectivity to deliver alerts to lifeguards in real time. Peplink provides that resilience, giving operators confidence that the system performs exactly as designed.
Daniel Mulvey
Connectivity is critical, especially when you are talking about saving somebody’s life or real-time operations.
Marcus Dowling
Deployment Architecture
Featured Products
Balance 310 5G / B One 5G
Deployed at larger multi-pool facilities running 20+ cameras
Provides reliable connectivity back to the internet, cloud services, and BlueFit systems
Supports SpeedFusion bonding or failover for added resilience at high-demand sites
BR Series / Transit Series
Deployed at smaller learn-to-swim sites with lower camera counts
Provides primary connectivity using fixed-line, fiber, or 4G/5G as available
Sized to match site data needs without overprovisioning equipment
Switch Series
Installed at every site, scaling from compact switches to up to 48-port PoE switches at larger facilities
Powers and manages individual camera ports, with per-port monitoring and remote restart
Connects poolside cameras to local systems and Lynxight's AI servers
Access Point Series
Deployed across all sites to provide Wi-Fi for smartwatches and workstations
Delivers consistent coverage across pool areas, decks, and surrounding facility spaces
Keeps lifeguards and duty managers connected to real-time alerts wherever they are on-site
InControl - Cloud Management
Centrally manages all Peplink devices across 30+ Lynxight-protected sites from a single cloud platform
Provides real-time visibility into network health to identify and isolate issues without on-site IT personnel
Supports BlueFit’s plans for expansion with a repeatable framework for configuring devices
SpeedFusion Technology
Bandwidth Bonding combines fixed-line, fiber, and 4G/5G connections into a single, higher-throughput link to support continuous data flow
Hot Failover seamlessly switches between connections to keep the workflow online even if one link drops
Keeps the link between poolside cameras and Lynxight's AI services stable, supporting real-time alert delivery
FAQs
Q1. How does Peplink support AI-powered monitoring systems?
A.
Q2. How can a Peplink network be managed across many sites with different layouts?
A.
Q3. Does Peplink have hardware that can handle harsh or demanding environments?
A.
Q4. What Peplink products are recommended for IoT, teleoperation or AI-related deployments?
A.
Next Steps
Talk to a Specialist
Share Your Story
