Slim Antenna Series
Slim Antennas
Applications
Recreational Vehicles
Transportation Connectivity
Enterprise Branch
Enterprise Branch
Ultra Wide Bandwidth
Wide frequency range (600-6000MHz) for LTE and 5G connections, including B71.
Built for 5G*
Omni-directional 2x2 or 4x4 MIMO mobile antenna for the best performance.
Wi-Fi^
2x2 MIMO dual band (2.4GHz & 5GHz) high gain omnidirectional antennas for local coverage.
*Slim 22G is equipped with 2×2 MIMO mobile antenna and Slim 40G is equipped with 4×4 MIMO
mobile antenna.
^Wi-Fi antenna only available for Slim 22G.
Built for 5G*
Wi-Fi^
mobile antenna.
Low Profile Design
High performance in a small, durable housing.
Easy Installation
Can be mounted on a window or wall or hidden under a vehicle dashboard.
Low Profile Design
Easy Installation
Can be mounted on a wall window or wall or hidden under a vehicle dashboard.
Which antenna is right for you?
- Understand the Name -
Slim 22G
2x Cellular | 2x Wi-Fi | 1x GPS
Slim 40G
4x Cellular | 1x GPS
