Back to List
Satellite Connectivity for Mining Sites: How Heathgate Stayed Online When Fire Hit Its Primary Link
A remote mine runs on its connection. Safety systems, daily operations, and the workers living on site all depend on it. Heathgate Resources used Peplink SpeedFusion to bond eight Starlink connections into satellite connectivity for mining sites that holds up when the primary link fails. When fire damaged the mine's microwave tower, the site kept running.
Summary
Organization
Heathgate Resources (uranium mining & processing)
Application
Primary-grade backup connectivity for a remote mine site, covering operations, safety systems, and workforce welfare
Solution Provider
MIMP Connecting Solutions (Peplink Reseller), with M2M Connectivity (Peplink Distributor) and Vocus (Satellite Provider)
Peplink Deployment
EPX, FusionHub, SpeedFusion, and InControl
Project Scope
Eight Starlinks bonded into one connection at the Beverley site, 650 km from Adelaide
Outcome
Up to 1.3 Gbps down / 250 Mbps up, and zero connectivity loss for 250+ workers when fire damaged the primary microwave tower
The Challenge
One Microwave Link and a 2 Mbps Safety Net
The Solution
A Single Bonded Connection Across Eight Starlinks
The Result
Zero Connectivity Loss When the Tower Went Down
Testimonials
This changes the landscape in Australian telecommunications. We can join multiple connection types together and present it to the customer as a single internet connection to use all the combined bandwidth at once.
Ashley Grove
Previously, our redundant communication option was a limited 2Mb/s satellite link. During outages, business communications were restricted to essential safety and operational services. The bonded Vocus Satellite–Starlink service has significantly improved our situation, allowing the mine site to keep operating even in unforeseen circumstances.
Hugh Banister
Deployment Architecture
Featured Products
EPX
Deployed at Heathgate Resources' mining site to bond eight Starlinks into one connection
Rated for up to 30 Gbps router throughput and 4 Gbps SpeedFusion VPN throughput, with capacity for thousands of concurrent users
Provides internet service for more than 250 on-site workers, well within its rated capacity
FusionHub
Established as an on-premise VPN concentrator
Acts as a SpeedFusion tunnel endpoint to the EPX
Eliminates the need for additional hardware
InControl - Cloud Management
Centrally manages the EPX and FusionHub deployment from a single cloud platform
Provides real-time visibility into network health
Supports the site remotely, without requiring IT personnel on-site
SpeedFusion Technology
Bandwidth Bonding combines all eight Starlinks into one higher-throughput connection
Keeps traffic flowing across the remaining Starlink if any one loses signal
Delivered up to 1.3 Gbps download and 250 Mbps upload once bonded, with zero downtime when a wildfire damaged the site's primary microwave tower
FAQs
Q1. How does satellite connectivity for mining sites keep a mine online when the primary link fails?
A.
Q2. How much bandwidth does a remote site need for both operations and workforce welfare?
A.
Q3. Does bonding Starlink connections require new hardware if a site already has satellite backup?
A.
Q4. How does Peplink support connectivity for remote sites vulnerable to disruption?
A.
Q5. How can organizations manage connectivity across remote sites?
A.
Q6. Can Starlink be combined with other internet connections?
A.
Q7. What Peplink products are suitable for remote deployments?
A.
Next Steps
Talk to a Specialist
Share Your Story
