Back to List
Peplink 5G Connectivity for AI-Driven Smart Construction with Peplink
One of the world's leading semiconductor manufacturers is using drones, AI-powered cameras, sensors, and connected vehicles to support environmental planning and site safety across its large-scale construction sites. Peplink provides the connectivity backbone that keeps these systems reliably connected.
Summary
Organization
One of the world’s leading semiconductor manufacturers
Application
AI-powered site safety, environmental planning, and digital twin applications
Solution Provider
NetBridge Technology (Peplink Distributor)
Peplink Deployment
Balance 310, BR1 Pro 5G, Antenna MAX, BR1 Mini 5G, SpeedFusion, and InControl
Project Scope
Multiple large-scale construction sites spanning 50 to 200 hectares
Outcome
A repeatable connectivity model supporting AI-powered smart construction
The Challenge
Reliable 5G for AI Applications from Day One
The Solution
A Scalable 5G Architecture Built for Performance
The Result
Scaling AI-Powered Construction from 50 to 200 Hectares and Beyond
Testimonials
Peplink enabled NetBridge to address complex field connectivity requirements with a flexible and scalable solution. The platform allowed us to respond quickly to deployment challenges and provide our customer with a reliable architecture for temporary site operations and future expansion.
Netbridge Technology
Deployment Architecture
Featured Products
Balance 310
Acts as the aggregation hub at each drone landing station
Bonds the connections from four BR1 Pro 5G routers into a single high-capacity link
Delivers up to 1 Gbps of bonded throughput via SpeedFusion
BR1 Pro 5G / Antenna MAX
Serve as the 5G WANs feeding the Balance 310
The pairing improves 5G signal reception and minimizes cable loss
Four are bonded per station through SpeedFusion to maximize uplink capacity
BR1 Mini 5G
Equips forklifts and electronic-fence cameras with compact 5G connectivity
Links onboard cameras and sensors locally over Wi-Fi, with 5G backhaul
Secures field data transmission with encrypted backhaul
InControl
Centralizes visibility and remote management of the Peplink fleet across multiple construction sites
Enables the team to monitor network status and support devices remotely
Helps maintain a consistent network architecture as the deployment expands
SpeedFusion
Combines four 5G connections into a single high-capacity link through Bandwidth Bonding
Supports Hot Failover to maintain a reliable data path for critical applications such as drone operations
Offers additional features such as Smoothing that can be enabled as needed to minimize packet loss
FAQs
Q1. What connectivity do AI-powered construction applications require, and how does Peplink support them?
A.
Q2. Why is 5G important for smart construction sites, and how does Peplink optimize 5G connectivity?
A.
Q3. How does Peplink hardware support different connectivity requirements across construction and drone deployments?
A.
Q4. How can Peplink networks be managed and scaled across multiple construction sites?
A.
Next Steps
Talk to a Specialist
Share Your Story
