Antenna MAX Duo
• Twice the Connectivity. One Seamless Enclosure.
Integrated Dual-Modem or Dual-Router Antenna Housing
Modem Top View
MAXed Out
Synergy
Two Modems.
One Setup.
Unlimited Possibilities.
Featuring 8x 5G/LTE, 2x Wi-Fi, and GPS antenna elements, the Antenna MAX Duo delivers reliable connectivity using two modems housed in a single, ruggedized enclosure. The integrated design removes the need for external RF cabling, reducing signal loss and setup complexity.
○ Supported dual-modem Peplink router setups include:
[ BR2 Pro ]
[ 2x BR1 Pro 5G ]*
[ BR1 Mini 5G + BR1 Pro 5G ]*
*Splitter MAX is required to provide power when more than one router is used.
Using the Splitter MAX, both connectivity and power are managed through a single PoE cable, simplifying installation and reducing cable clutter.
○ Suggested cable path for dual-router setups:
MAXed Out Ruggedness
Built to endure the elements, the Antenna MAX Duo is engineered for harsh environments with a UV-stable, waterproof IP67-rated enclosure and flame-retardant, UV-resistant plastics. Compliant with MIL-STD 810F salt spray standards, it’s ready to perform reliably on land, at sea, and on the move.
MAXed Out Flexibility
Whether installed on a vessel, vehicle, or fixed location, the Antenna MAX Duo adapts to your deployment.
○ Set it up how you see fit with multiple mounting options:
Surface Mount
Pole Mount
(vertical or horizontal)
Compatible with standard 3rd party maritime VSAT dome mounts
(not included in package)
MAXed Out Savings
The Antenna MAX Duo delivers unmatched value by combining high-performance antenna arrays, robust protection, and dual-modem support into a single, compact enclosure.
It’s a space-efficient, time-saving, cost-effective, and performance-maximizing solution for maritime, mobile, enterprise, and remote deployments.
Photos
Antenna_MAX_Duo_front Antenna_MAX_Duo_persp
