8 Additional SIM With the SIM Injector
Use the SIM Injector to add another 8 SIM cards to your deployment, giving you the ability to connect to multiple carriers and ensuring that your connection remains unbreakable. The SIM Injector is capable of PoE output, so you don’t need to add another PoE switch to your deployment.
100 meter flexibility can be added with SIM Injector
In addition to adding SIM capacity, the SIM Injector also adds 100 meters of flexibility between the Router and the SIM cards, enabling you to place the cellular router anywhere you want without worrying about changing SIM cards.
SIM Injector uses a flexible architecture
You can connect multiple SIM Injectors to your device, and it will have access to all the SIM cards carried by the SIM Injectors.
