BR Pro Family
The New Benchmark for Professional Connectivity
X65 5G Modem
5G SA & Network Slicing
PoE+ Input
Docker Support
Flexible SIM Options
SpeedFusion
360° Hardware View
Advanced 5G Performance
Powered by the X65 5G modem, both routers support standalone (SA) and non-standalone (NSA) 5G modes with enhanced carrier aggregation capabilities, delivering increased throughput and faster speeds across public and private 5G networks.
SA Mode
NSA Mode
LTE Fallback
Private 5G Networks
Network Slicing
Higher Peak Theoretical Performance
(On sub-6 GHz 5G)
X65 5G Modem
4.1 Gbps
X62 Modem
3.4 Gbps
Streamlined, Flexible Deployment with PoE Power Input
Power over Ethernet (PoE) input simplifies installation and cabling, allowing the BR1 to be placed in locations with better signal reception, without needing a nearby power outlet.
Smarter Operations with Edge Computing
Run custom applications directly on the device with built-in Docker support and onboard storage, enabling agile performance, seamless integration, and streamlined deployment and management.
Government-Ready: TAA Compliant
Meet federal and government requirements with full TAA compliance for secure and regulated deployments.
Priority for Public Safety
Ideal for public safety environments, both routers carry AT&T FirstNet and T-Mobile T-Priority certifications and are Verizon Frontline verified, ensuring prioritized and reliable connectivity during mission-critical operations.
Flexible SIM Choices for Any Situation
Use eSIM for greater efficiency and instant connectivity, with the option to use physical SIMs when needed.
Seamless Failover for Starlink, Fiber, and FWA
Seamlessly integrate 5G with Starlink, fiber, and fixed wireless access (FWA) through SpeedFusion to deliver uninterrupted connectivity. Stay reliably online, always.
| Category | Features |
| Software | Peplink MAX Firmware |
| WAN | Support for PPPoE, Static IP, DHCP WAN Link Health Check Bandwidth Allowance Monitor Support for Dynamic DNS services WAN Port Convertible into LAN Port |
| Load Balancing | Multiple Outbound Policy Algorithms • Weighted Balance • Priority • Overflow • Persistence • Least Used • Lowest Latency • Enforced • Fastest Response Time |
| Security | Stateful Firewall DoS Prevention Web Blocking |
| Complete VPN Solution | SpeedFusion VPN • Site-to-Site VPN • 256-bit AES Encryption • Pre-shared Key Authentication • Dynamic Routing X.509 Certificate Support * IPsec VPN (Network-to-Network) ^ Remote User Access (PPTP/L2TP/OpenVPN) |
| Edge Computing | Support on Applications and Docker |
| Advanced QoS | Individual Bandwidth Limit Application Prioritization • SIP, HTTPS, VPN QoS • Custom Application QoS |
| Global Positioning System | Integrated GPS Device Location Map Location Tracking Data with InControl 2 Fleet Management with InControl 2 |
| Networking | NAT and IP Forwarding Static Routes Port Forwarding Many to One, One to One NAT NAT Pool SIP ALG, H.323 ALG UPnP, NAT-PMP |
| AP Controller | Support for Peplink AP Series Auto AP Discovery Auto AP Firmware Management AP Profile Configuration Wi-Fi Usage Statistics |
| Captive Portal Support | Support for Wired LAN clients Support RADIUS Authentication Time and Usage Quotas on Open Access Mode Built-in Customizable Splash Page |
| Device Management | Web Administrative Interface Command Line Interface InControl 2 Cloud Management Email Notification Active Client & Session Lists Bandwidth Usage Statistics Syslog Service SNMP v1, v2c and v3 |
| Product Code | Region | 5G Bands | LTE Bands |
| MAX-BR1-PRO-5GK-T-PRM
Embedded Modem(s):
1x 5G | Global
US Carrier Certifications: AT&T, T-Mobile, Verizon, FirstNet | 5G (NSA & SA) Sub 6Ghz: n1, n2, n3, n5, n7, n8, n12, n13, n14, n18, n20, n25, n26, n28, n29, n30, n38, n40, n41, n48, n66, n71, n75, n76, n77, n78, n79 | B1, B2, B3, B4, B5, B7, B8, B12, B13, B14, B17, B18, B19, B20, B25, B26, B28, B29, B30, B32, B34, B38, B39, B40, B41, B42, B43, B46, B48, B66, B71 |
| PRM-C-1Y | PrimeCare C (1-Year) |
| PRM-C-2Y | PrimeCare C (2-Year) |
| PRM-C-4Y | PrimeCare C (4-Year) |
| PCP-C-1Y | PrimeCare+ C (1-Year) |
| PCP-C-2Y | PrimeCare+ C (2-Year) |
| PCP-C-4Y | PrimeCare+ C (4-Year) |
| ACW-634 | 10ft DC Power Cable |
| ACW-643 | Vehicle Cigarette to Molex Power Cable |
| ACW-791 | Peplink 4-Pin to USB-C Power Cable |
| ACW-DIN-BR1 | DIN Rail Mount for BR1 Pro and BR1 Mini Series |
| ANT-SLM-40G-S-B-6 | Slim 40G - 4x4 MIMO 5G Ready Cellular Antenna System with GPS (Black) |
| ANT-MB-42G-S-W-6 | Mobility 42G - 4x4 MIMO 5G Ready Cellular and Wi-Fi Antenna System with GPS (White) |
| ANT-MB-42G-S-B-6 | Mobility 42G - 4x4 MIMO 5G Ready Cellular and Wi-Fi Antenna System with GPS (Black) |
| ANT-MAX | Antenna MAX - Enclosed with 4x LTE/5G, 2x Wi-Fi, 1x GPS 600-6000MHz, IP67, SMA male (Cellular, GPS), RP-SMA male (Wi-Fi), White |
| ANT-MAX-S | Antenna MAX S - IP-rated integrated antenna enclosure for hybrid cellular and Starlink Mini connectivity |
| Package Content |
| 1x BR1 Pro 5G |
| 1x 12V 2A 4 Pin Power Supply (ACW-632) |
| 4x LTE/5G Antennas |
| 2x Dual Band Wi-Fi Antennas |
| 1x GPS Active Antenna |
| MAX-BR2-PRO-5GK-T-PRM
Embedded Modem(s):
2x 5G | Global
| PRM-E-1Y | PrimeCare E (1-Year) |
| PRM-E-2Y | PrimeCare E (2-Year) |
| PRM-E-4Y | PrimeCare E (4-Year) |
| PCP-E-1Y | PrimeCare+ E (1-Year) |
| PCP-E-2Y | PrimeCare+ E (2-Year) |
| PCP-E-4Y | PrimeCare+ E (4-Year) |
| ACW-111 | PoE Adapter |
| ACW-622 | PoE+ Activation Kit |
| ANT-MB-82G-S-W-6 | Mobility 82G - 8x8 MIMO 5G Ready Cellular and Wi-Fi Antenna System with GPS (White) |
| Package Content |
| 1x BR2 Pro |
| 1x 12V 3A 4-Pin Power Supply (ACW-663) |
| 8x LTE/5G Antennas (ACW-235) |
| 2x Dual Band Wi-Fi Antennas (ACW-341) |
| 1x GPS Antenna (ACW-232) |
